aftermarket springs anyone?
67highboy
re: aftermarket springs anyone?
Post by 67highboy »
:yt:
Ben Franklin 1775
benm78
Post by benm78 »
Spring rate is based on wire diameter, coil diameter and spring pitch. Load is then based on number of coils.
pat67shorty
Re: re: aftermarket springs anyone?
Post by pat67shorty »
FORDification wrote:The stock front truck springs are already a lot stiffer than that, and trust me, once you cut the stock springs, they'll be stiffer!
In '69, for example, the stock Ford F100 front coils were available with 1055, 1175, and 1265 lb. spring rates. The F350 springs were available in 1365 and 1430 lb. spring rates. You could easily pick up a pair of F250 (or even F350) springs for next to nothing and cut one coil off each, which would be stiffer than what you've got now, plus would lower the 1"-2" you're looking for.
Just my :2cents:
Umm... those are weight ratings right? Not spring rates....? Cause the 450lb spring rate coils for my BII are damn stiff... I'd think a spring with a 1,000+ rate would be like a 4x4 block of wood between the axle and frame..
'67 SWB, 1970 car 390, Edelbrock Streetmaster intake, MSD 6AL, 780 Holley, Hedman headers, 2.5 duals, 3.54 D44 L/S, C6.
