1972 F250 radius arm bushing, ADJUSTABLE ONES AVAILABLE?
I am rebuilding my front suspension on my 72 F250 CS. Does anybody make adjuable radius arm bushing kits? I would like to have some caster adjustabillity. Thank U in advance, newbie, MR_J_ DAHMER
Last night I heard my neighbor's cheby rusting away...
- mrung0wa
re: 1972 F250 radius arm bushing, ADJUSTABLE ONES AVAILABLE
Whoa There!
Are you talking about bushings for the Twin I-Beams?
How can the radius arm bushings, adjustable or not have an effect on the Caster?
Remember now, I am the Village Idiot.
Lawrence
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
no they don't make them. and putting washers in there is just a bad idea.
don't do it . it will through everything out and will ware the center pivot bushing out. if you want more caster go to a repair shop. they may just be able to use some off set bushings in the king pins , although it unlikely the shop will. I did this once & it a pain setting them up. and the effect is very minimal. I would just set the toe and call it good.
WHAT ?
Caster is not adjustable through the radius arm bushings, at least not like it is for imports using a MacPhearson strut set-up. Caster is built into the I beam and like was said before, the adjuster kits for it don't provide much adjustment. If your caster is off, then there is a damaged beam or spindle.
Ok I really did not want to tell anyone but once and only once I did heat the hell out of a set of I beams and bent & twisted the thing in order to get a better front end set-up.
now that bin said DO NOT EVER DO THIS on any vehicle. it is just not safe. I did this only for a race truck and I ended up almost killing a good friend when the I beam snapped. Sorry buddy.
WHAT ?
