Open or limited slip?
Moderator: Doug Comer
- broke_okie
I have my 3rd member out , it is out of a 71' F100 4x4. I have it sitting on my bench because I am installing a powertrax locker in it. The directions say If your vehicle has a limited- slip differential, it will be necessary to purchase a standard differential case assembly,cross pin,retaining pin, and side gear thrust washer for your axle. The tag from my rear dif shows that it is a limited- slip I believe because ...it reads 3L50 9 . 3363a. But how do I tell by looking at the third member ? I have it on the bench and want to know if I can tell if it is limited-slip or not by looking at it? The tag could have been put on by the smart ass kid I bought the truck from years ago. Can anyone help me on this? Thanks
J.P.-"Happiness is... not being smart enough to know what to worry about."
** 1971 F100 SWB 4X4 SPORT CUSTOM**
- heep70
Post a pic or two.
You are doing the 9"? Its kinda hard to tell the differnce between a clutched locker carrier and an open carrier. the detriots are the easiest.
Did you splite the center yet?
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- broke_okie
re: Open or limited slip?
I used the exploded veiws section and found it to be a limited slip...yep it has the clutches. Thanks I love this website.
- heep70
Good job ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
Greg
- 390Nut
Very quick way to tell a OEM locker from an open, (on the 9" at least) is the locker will have the bolts countersunk (recess cut) on the spool with 5/8" bolt heads, while the open carrier will have 3/4" bolt heads and a flat surface (no recess) on the spool.
Here's a link to some info on 9" axle ID:
http://www.kevinstang.com/Ninecase.htm
Paul
![Image](http://img.photobucket.com/albums/v169/FrayedSanity/ford1.gif)
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- 68half/step4x4
