Removing trim on windshield and rear window
- Ron_Hall
Hey guys.. I'm getting ready to replace my windshield and rear window and would like to know how to remove the chrome trim without screwing it up.
Ron
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
One owner...
- basketcase0302
Re: Removing trim on windshield and rear window
It's one thing I've never done on a bump in over 35 years of owning and working on them."Ron_Hall"Hey guys.. I'm getting ready to replace my windshield and rear window and would like to know how to remove the chrome trim without screwing it up.
Ron
AND HOPE I NEVER DO (from all the cussing I see guys doing especially when reinstalling it) LOL!
Keith has written a tutorial on it that describes it really well:
http://fordification.com/forum/viewtopi ... 46&t=40806
Are you using new rubber? if so just cut the rubber seal inside the cab and remove the window with the trim all at once. then carefully remove the trim.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
1962 Fairlane 500 Sports Coupe
VW Sandrails
Honda ATC's
36' Diesel Pusher for roughing it.
1976 Highboy
VW Sandrails
Honda ATC's
- jzjames
From my experience, the difficulty in installing a windshield with metal trim is that the metal trim has gotten distorted - even slightly - and it causes a resistance to the rubber lip being pulled over the edge of the windshield opening.
take extra care not to bend or distort the metal trim when removing the old gasket AND when placing the metal trim into the groove of the new gasket before installation.
You want that shape to be exact, - as close to the way it was when installed on the truck.
Then put your string in (I’ve been using single strand of speaker wire) use your lubricant (windex is good) and position the unit against your opening but don’t let it all slide toward the bottom - try to keep it more uplifted so it is all better centered all the way around the whole windshield opening.
Or, let a pro do it. Don’t distort that SS trim.
- Ron_Hall
Hey Bill, good idea!! and yes, new rubberBill Ramsey wrote:Are you using new rubber? if so just cut the rubber seal inside the cab and remove the window with the trim all at once. then carefully remove the trim.
thanks
Ron
One owner...
One owner...
- Ron_Hall
jzjames, some very good ideas.. Thanksjzjames wrote:From my experience, the difficulty in installing a windshield with metal trim is that the metal trim has gotten distorted - even slightly - and it causes a resistance to the rubber lip being pulled over the edge of the windshield opening.
Glass people around Reno want $1200 plus the windshieldOr, let a pro do it. Don’t distort that SS trim.
Ron
One owner...
One owner...
- Ron_Hall
I don't know how I missed that read... He makes it look sooo easy.basketcase0302 wrote:It's one thing I've never done on a bump in over 35 years of owning and working on them."Ron_Hall"Hey guys.. I'm getting ready to replace my windshield and rear window and would like to know how to remove the chrome trim without screwing it up.
Ron
THANKS!!
Ron
One owner...
One owner...
i'm having mine done next week. local glass guy , $250 installed. asked him about the trim, said no problem, he's done quite a few.
double post
Ron: The only word to describe that is EXORBITANT!!
Being in Reno, they were probably GAMBLING that you'd bite:):)
Ron_Hall wrote: Glass people around Reno want $1200 plus the windshield
Ron
- Ron_Hall
Well, they lose because 2 days ago I found an older company that will do it for $265 windshield, labor and install the SS trim!!jamesdfo wrote:Ron: The only word to describe that is EXORBITANT!!
Ron
I'm happy again.
Ron
One owner...
One owner...
- Idaho Chris
I don't suppose there is a re-installation tutorial? I understand the trim goes on before the windshield is installed?basketcase0302 wrote: ...Keith has written a tutorial on it that describes it really well:
-Chris
1969 F250 4x4 4spd 300 I6
1973 Mustang Mach 1 351C
yes, is there a reinstall thread?
- Ron_Hall
https://www.youtube.com/watch?v=C97jRVagtvAZorm wrote:yes, is there a reinstall thread?
Zorm... this might help. One thing they do is start the install in the lower channel first but I have heard that Ford recommends you start the upper first.
Ron
One owner...
One owner...
Here is a thread on how someone else did the re-install on the windshield with stainless trim:
http://www.fordification.com/forum/view ... =7&t=63120
Regards
Regards
