Just make sure the hoist will go under the suspension it you let air out of tires Just like emeraldcoupe said take it slow and steady. I pulled many engines with trans still on. I put a 429 auto in my 72 shortbed with an engine crane. I did not take the hood off. That was VERY interesting to DO! It was veryyyy close to everything!!emeraldcoupe wrote:I just pulled the 360 and c6 from my 71 as one, all I removed was the hood. just go slow and you'll be fine.
for a few extra inches of clearance, let the air out of the front tires.
1967 f100 engine removal procedure questions
Re: 1967 f100 engine removal procedure questions
daveford72 wrote:Just make sure the hoist will go under the suspension it you let air out of tires Just like emeraldcoupe said take it slow and steady. I pulled many engines with trans still on. I put a 429 auto in my 72 shortbed with an engine crane. I did not take the hood off. That was VERY interesting to DO! It was veryyyy close to everything!!emeraldcoupe wrote:I just pulled the 360 and c6 from my 71 as one, all I removed was the hood. just go slow and you'll be fine.
I still had about 2" of clearance for the hoist with the tires flat, fwiw
