One Bad 68 Ranger Grille
1964 f100
292 yblock
1969 Ranger
Loving all ford vehicles
292 yblock
1969 Ranger
Re: One Bad 68 Ranger Grille
Mr Chico, your grills are beautiful.
Good job .
Good luck.
Good job .
Good luck.
- hdman90
chicof100 wrote:https://www.ebay.com/itm/273045007504?s ... 1558.l2649
Chico, you're the one who does the grilles?!
Yes I am, how can I help you?hdman90 wrote:chicof100 wrote:https://www.ebay.com/itm/273045007504?s ... 1558.l2649
1964 f100
292 yblock
1969 Ranger
292 yblock
1969 Ranger
- hdman90
You're a legend! I've always seen your work and admire it very much, but never thought I would cross paths with you! Keep up the good work sir!chicof100 wrote:Yes I am, how can I help you?hdman90 wrote:chicof100 wrote:https://www.ebay.com/itm/273045007504?s ... 1558.l2649
I'm flattered, Thank you for the kind words. I've slowed down a bit, but the quality is better. Thank you again.hdman90 wrote:You're a legend! I've always seen your work and admire it very much, but never thought I would cross paths with you! Keep up the good work sir!chicof100 wrote:Yes I am, how can I help you?hdman90 wrote:
1964 f100
292 yblock
1969 Ranger
292 yblock
1969 Ranger
Thank you Sir, Yours and other comments like yours, is what keeps me going. Thank you again.crazyhorse wrote:Mr Chico, your grills are beautiful.
Good job .
Good luck.
1964 f100
292 yblock
1969 Ranger
292 yblock
1969 Ranger
Any chance you can share your process steps?
1967 F-100 4x4 custom cab.
Strip, Fix and polish. Polishing is dangerous to achieve this takes time and more time. You don't start out by doing a grille.Busboy wrote:Any chance you can share your process steps?
1964 f100
292 yblock
1969 Ranger
292 yblock
1969 Ranger
How much time does it take to restore one? Do you find these in typical salvage yard condition when you run across them?
Approximately 13 shop hours depending on damage. Then about 8 hours at home doing hand polish and sealer, plus re-assembling.Busboy wrote:How much time does it take to restore one? Do you find these in typical salvage yard condition when you run across them?
90% are wrecking yard finds others I purchase from people who have them to sell.
1964 f100
292 yblock
1969 Ranger
292 yblock
1969 Ranger
