Hey guys. I ordered door jamb switches for my truck (link below) and I'm having a hard time finding the proper pin connector that fits. Anyone have a link or recommendation of what to get?
http://dennis-carpenter.com/dome-light- ... Z-13713-C/
Electrical Pin Connectors for Door Jamb Switch
- Ranchero50
Re: Electrical Pin Connectors for Door Jamb Switch
Notice the list of vehicles that that switch fits? Junk yard trip and get a bunch because the little clips break way too easily.
I'm referring to the actual terminal connector that fits in the 2 female holes. A standard bullet connector won't fit, and a GM/Ford terminal from Autozone won't either.
Easiest thing to do would be to find a similar switch that you CAN find the harness to and modify your bracket to fit that switch. Maybe something from a 1st generation Mustang. There are a lot of aftermarket repros for Mustangs.
- Canonman67
- basketcase0302
Randy's on the right path here folks. After years of chasing door switch issues I finally switched the simple two wire harness out at the door to the dentside era, (I had several of these at one time-they are still easiuly obtained via boneyard as well as several places repoing the switches including DC) which will last you 50 years without ever going back to:sargentrs » Fri May 06, 2016 6:59 pm
Here's the difference in the original little prickly pins versus the dent era:
http://thumbs2.picclick.com/d/l400/pict ... 3713-A.jpg
- Ranchero50
In agreement with what the other said. Ford made a plug to fit this switches and used it on all of that generation vehicle. The dentside version used the next generation of connectors that was more robust. Either style I would not try to use generic bullet connectors but solder and shrink wrap a OEM connector back to your harness.kmcypress wrote:I'm referring to the actual terminal connector that fits in the 2 female holes. A standard bullet connector won't fit, and a GM/Ford terminal from Autozone won't either.
You may want to try Digikey Electronics in MN. They have zillions of different pins and connectors. I bought male and female bullet connectors that have an extended back end so I can push the connector into the mating unit... pushing on the metal rather than the wire. Slip a piece of 1/4" ID shrink tubing on the end, heat and it looks good much like the original Ford connectors. Will mate to the original stuff since it the correct .180 diameter. Also bought from them the right angle slip on connector used for the oil sender. Paid more for the shipping than the quantity I bought. Good luck.
66 F250 camper special
69 F250 Explorer
85 Mustang GT with 1900 original miles
92 Festiva with 538,000 original miles
86 E350 extended WB van
Various IH & JD tractors (5)
TT & XT500 mc's (6)
BSA, Triumph's and twenty Yamaha two strokes
69 F250 Explorer
TT & XT500 mc's (6)
Appreciate all the feedback guys!
