I have a 1997 Ford Expedition 4x4. The tranny was replaced a few years ago. I am trying to find out what tranny is in my vehicle. The ID codes on the tag are as follows:
A287 3 4406-17
154523 F75A-CC
Also I found the following on the Bell Housing:
RF-F2TP-7A040-BA
I cannot find any other tags or info anywhere.
Thanks;
Smife
Transmission ID
Re: Transmission ID
Hi, if it is a 5.4 engine with a towing package, my guess is that is an E4OD
if is a 4.6 it may have a 4R70w.........count the bolts in the pan ,or describe the shape of the pan.
Most likely a Ford tech will chirp in with the correct info for your F2 # .....as I am just going from memory....Donnie
Re: Transmission ID
Look on the drivers door tag/door jamb under the "Trans" heading. If the transmission code is "U" then it is a 4R70W. If it's some other code, sorry, can't help ya.
Steve
- HIO Silver
Re: Transmission ID
smife wrote:I have a 1997 Ford Expedition 4x4. The tranny was replaced a few years ago. I am trying to find out what tranny is in my vehicle. The ID codes on the tag are as follows:
A287 3 4406-17
154523 F75A-CC
RF-F2TP-7A040-BA
Re: Transmission ID
No one is going to be able to tell you what your transmission is when you post TRANSFER CASE tag numbers. We need TRANSMISSION tag numbers.I have a 1997 Ford Expedition 4x4. The tranny was replaced a few years ago. I am trying to find out what tranny is in my vehicle. The ID codes on the tag are as follows:
A287 3 4406-17
154523 F75A-CC
RF-F2TP-7A040-BA
mmerlinn (http://mmerlinn.com/catalog/makeridx.htm)
"People who are careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Steven Raymond
