radius arms- how tight?
- Billybobjunky
ok guys, i don't really have any idea on this one. the bolts attaching the radius arms to the i-beams, the ones that share the coil spring pads along with it. how tight should they be? should they be all the way so that my radius arms don't pivot at all, or should the radius arms be free to wander? thanks guys
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
-Re-wired main harness
-Disc Brakes/Power Steering
-'77 V8 [[[410]]]
-'74 C6
- boots
re: radius arms- how tight?
I dont think the radius arms are suppose to wander at all, just get it all positioned in the bracket, then tighten it.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Billybobjunky
OK, now how tight should the bolt be that is retaining the radius arm bushings? Should I tighten it as much as I can or is there a desired torque?
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
-'77 V8 [[[410]]]
-'74 C6
- boots
Re: re: radius arms- how tight?
wait for some more posts to come in to see how tight they need to be exactly, I need to know as wellBillybobjunky wrote:OK, now how tight should the bolt be that is retaining the radius arm bushings? Should I tighten it as much as I can or is there a desired torque?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- 68F250
180 - 220 ft.-lbs.
Barry
radius arm bushing bolt is 80-120 ft pounds. The bolt holding radius arm to I beam is 269-329 ft lbs.<- But that one I just did as tight as I could, becuase my torq bar didnt go that high.
chilton ford pickups 1965-84. Also I have a shop manual to.
