5 speed trans or c4
randyj68
5 speed trans or c4
Post by randyj68 »
I have a posting in the engine section but wanted to toss one on here as well. I have a 68 ranger, original 390 3 speed. I want to go to a 302, preferrably 5 speed but considering a c4 or c6. A friend of mine has a 66 mustang, 302 and had a 5 speed in it for a long time before getting a world class t5 and found that the 5 speed he had been running was out of a 6 cyl tbird......said he always thought 1st gear was low, anyway i'm curious what 5 speed trannys will bolt up to a 302, how hard its going to be to put it in or if a c4 or c6 would be a better way.....just like to gewt some input
"Ashes to ashes, dust to dust, if it wasn't for chevy's our tools would rust".
BobbyFord
Re: 5 speed trans or c4
Post by BobbyFord »
It depends on what you are going to use the vehicle for. AOD is also an option.
fbomb100
Post by fbomb100 »
BobbyFord wrote:It depends on what you are going to use the vehicle for. AOD is also an option.
:yt: what he said
randyj68
Post by randyj68 »
Like to use it for daily transportation at some point (have to get something other than the 2/60 air conditioning) want to drive it pretty much anywhere, have some fun with it. Also, it has a 3:25 gear
ultraranger
Post by ultraranger »
T-5's were all World-Class from 1985-on. 2.3L 4-cylinder T-5's generally had 4.03 or 3.97:1 1st gear ratios. 5.0L Mustang GT/LX T-5's had a 3.35:1 1st gear (wide ratio gear set). '93 Cobra Z-spec T-5's had a 2.95:1 1st gear ratio (close ratio gear set).
Improvements were made to the T-5's in 1990. Best factory T-5 transmissions came in the 1990-1993 5.0L Mustangs/Thunder Birds or from the '93 Cobras.
1994/'95 Mustang T-5's have longer input shafts and a deeper bell housing than previous T-5's.
AOD automatics came out in 1980. Worst year model AOD's to have are 1980-1987 due to lack of lubrication and some internal design flaws. Many AOD design problems were addressed with the '88-'93 models.
A much improved electronic-shift version of the AOD came out in the '94/'95 Mustangs, known as the AOD-E.
An even better evolution the AOD/AOD-E was the the 4R70W 4-spd automatic transmission that came out in 1993. Best year models of it are from 1998-2003 3.8L Mustangs, 4.2L Ford F150/E150 or from 5.0L Explorers. You do not have to have fuel injection to run a 4R70W. It will work with either carburetion or fuel injection, with a stand-alone shift controller. (2) starter bolt holes in the bell housing means it will fit a 'Windsor' block pattern. (3) bolt holes in the bell housing indicates the transmission is for a 4.6L/5.4L engine.
If the vehicle is going to see a lot of highway driving, an overdrive transmission is going to make it a lot more pleasant than having a non-overdriven C-4/C-6.
http://ultrastang.com/info3.php
Steve
randyj68
Post by randyj68 »
WOW! That info is really appreciated......can never have too much information
ron hyde
Post by ron hyde »
I'm installing a TKO 600 with a quicktime bell housing in my 68 390ci F250.
ron hyde
Post by ron hyde »
Started my Tremic TKO 600 conversion today,removed the old 4 speed and installed the new Mcleod steel flywheel and clutch assembly. Tomorrow I'll install the Tremic and button it all up. I'd post pictures but I have no idea how to do it on this site.
randyj68
Post by randyj68 »
Ive found that photobucket is the best way to do pics because of the size requirements. I am really confused on some things. I have a 91 302 and pulled the 5 speed out of a 98 mustang 3.8, same bolt pattern. Why can I not use the 3.8 flywheel and clutch? Assume I habve to use the 3.8 starter....
ron hyde
Post by ron hyde »
Ok well the trans is in and almost finished just waiting to get my driveshaft back in the morning and need to make a trans tunnel cover. I guess I'll use a shifter from my mustang conversion until I custom build one around the seat.
Broncobilly66
Post by Broncobilly66 »
I'm going efi roller 302 and aod. 3.73 gear. ..I think it'll be a sweet setup.
'68 SWB custom cab Bump. Under construction.
'66 bronco
'68 bronco
ron hyde
Post by ron hyde »
Truck drives nice with the 5speed big improvement over the old 4speed,finished the shifter and its off to the plater and now need to order carpet. Thinking I might look for a nice f100swb to play with now.
sargentrs
Post by sargentrs »
:clap: Congrats!
randyj68
Post by randyj68 »
Ok, this is the million dollar question. How do i find out if the flywheel from a 98 mustang 3.8 is 50 ounce or not or if the 98 3.8 mustang hhad a 50 ounce harmonic balancer.....im having no luck on the net
9t3svt
Post by 9t3svt »
As stated in the other thread, you need a flywheel for a 302 in a later model truck. That will get you 50oz imbalance and 164 tooth ring gear. If you lived close enough I could give you one. You CANNOT use your 3.8 flywheel as the balance is incorrect.
