coil springs
re: coil springs
You gotta keep in mind that these are trucks we're talking about, not cars. These trucks were specifically designed to carry heavy loads. If they came out level from the factory, then any time you put anything in the bed, the rear half would drop down and the front would raise up. That wouldn't be good...the steering gets a little more squirrely and reduced visibility becomes a factor. Plus you end up looking like a dork.
Therefore, they installed heavy springs on the back which can handle the weight of cargo. Even putting very heavy cargo back there will simply make the back end squat down more, for the most part. You'd have to virtually exceed the factory GVW rating to get the truck loaded down so far that the rear would be lower than the front...and that's by design.
Since the factory's design is to have the rear half higher than the front, that means that even after you remove the add-on parts put there by a previous owner (overload springs and coil-over shocks) you will have reduced the load capacity of the truck, but it's not going to be any lower than it was the day it rolled off the factory floor. The back end is still going to be higher. To level the truck out you're going to have to 'reverse-enginneer' the factory's work....which means installing drop shackles, and/or de-arched springs, and/or rear-end flip kit.
re: coil springs
Ok well see I don't need them any ways. I'll keep you guys informed on the outcome. I'm hopeing to level it the inexpensive way. thanks...
