ford 9 inch
ford 9 inch
Ford 9 inch
Mike- (72 SWB Chassis, 68 Ranger body, 69 Ranger grill) 72 302 bored 30 over, 69 351w heads light port work, Erson TQ20H cam, Weiand Stealth intake, Edelbrock 1406 carb, MSD 6T circle track ignition controller, C4 with transgo shift kit, Ford 9inch rear with Eaton Truetrac LSD. Much more in the works!
- Hawkrod
Re: ford 9inch with 373s out of 68 f100
Where did you get 3.73 for a 9 inch? Ford never made them. Hawkrod72customF wrote:Have a 9inch out of a 68 f100 with 373s also have the drive shaft... both have been sand blasted and epoxied black both are fresh message me with and offer. Have about enough parts to build 3 truck so if you need it I prob have it.
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
ford 9 inch
Ford 9 inch
- 69f-100
hawk is right,Hawkrod wrote:Where did you get 3.73 for a 9 inch? Ford never made them. Hawkrod72customF wrote:Have a 9inch out of a 68 f100 with 373s also have the drive shaft... both have been sand blasted and epoxied black both are fresh message me with and offer. Have about enough parts to build 3 truck so if you need it I prob have it.
- FREAKSHOW
he is correct they do not make 3.73 for a 9 inch, they do make a 3.70 thoughHawkrod wrote:Where did you get 3.73 for a 9 inch? Ford never made them. Hawkrod72customF wrote:Have a 9inch out of a 68 f100 with 373s also have the drive shaft... both have been sand blasted and epoxied black both are fresh message me with and offer. Have about enough parts to build 3 truck so if you need it I prob have it.
ford 9 inch
Ford 9 inch
