I got a good deal on four shocks for the truck but I have never installed any myself. Got any tips for me to save time/effort?
I'm a newbie DIY'er, so anything is appreciated.
Never installed shocks before
- 91Bear
- TX69F100
Re: Never installed shocks before
I have not yet replaced the ones on my bump. However, shocks in general are a pretty easy part to replace (especially when not part of a strut).
Here is a general how-to from Autozone:
http://www.autozone.com/autozone/repair ... le=replace
Looks like there just a nut on top and a bolt through the bottom up front: http://www.autozone.com/autozone/repair ... le=replace
Then you have a bolt through the top and the bottom out back: http://www.fordification.com/tech/image ... noflex.jpg
You should be able to do the swap without lifting/supporting the suspension (unless you just want to put it up the air to get more clearance to crawl under it).
Just did mine a month or so ago. Very easy removal/installation probably a hour or less for the total project. One bolt through the bottom and one nut to remove from the top. Only tip I have is remove the top one first so the shock doesn't try to turn as you loosen/tighten the top nut.
- 91Bear
Do the shocks usually come with the required bushings?
- 1972hiboy
normally the new shocks should come with all the new/needed bushings and hardware.
Rich
Dont eat yellow snow.....
How tight does that top nut need to be on the front shocks. I just replaced mine last week and when tightening the nuts on one side the tire was raised off the ground and the other tire remained on the ground. I had the truck on jack stands. And both nuts are tightned the same distance down the stud.
Common Sense is an Uncommon Virtue
the nuts should be tight so that it lets the bushing mash to the frame bracket. maybe something else is wrong. the shocks dont match or a bracket is bent. a spring could be worn on one side. or not the same amount of leafs. the frame could be bent.
Hey 91 Bear. Installing the shocks shouldnt be very difficult. Here is my thread as I just installed a set last month but mine were a HD shock with a coil over it which did make it a little more difficult to install the front shocks because you have to kind of compress them before installing them. Nothing too difficult, just a small additional challenge http://www.fordification.com/forum/view ... =5&t=55900. I did raise the vehicle and place on jack stands when I did mine.
'72 F250,390,C6,76K Sport Custom, Camper Special "Ole Blu"
'90 F250,460,48K XLT Lariat, Supercab
'88 Lincoln Mark VII LSC, 5.0 H.O.original, was daily driver, now retired
'97 Lincoln Town Car-Cartier,73K, 4.6, fact. dual exhaust,mint/original-Last Big Towncar
'05 GMC Denali XL,6.0 Vortec-for the wife & kids
'02 Cadillac DHS,4.6 Northstar-daily driver
'73 Great Divide 22' travel trailer,restored to original
'79 Mitchell 11' "Challenger XL" cabover camper-restored to original
'88 Lance 11'3" LC 780 cabover-current project
