brake union compression fitting
onetuford
Post by onetuford »
Is it really illegal to sell a compression fitting for an auto brake line? I went to NAPA today to pick one up and he refused to sell me one. He said it was illegal. I was able to get a union and some nuts since I own a flaring tool. I prefer to do it that way, but never did in the past. I swear I've bought at least 10 of those in the past to put brake lines together. Anyone else ever heard of this?
"I'm not saying, I'm just saying"
1972 Ford F250 C/S XLT 390 NP435, purchased from the son of the original owner, now named Yoda
1967 Ford f100, currently. (2nd Titled owner) Now named Captian Hook
Re: brake union compression fitting
yes it is illegal to use a compression fitting on brake lines. that is why they say they wont sell them. but if you tell them your not workign on brakes for a truck they cant say that. you tell them its for something else.
70_F100
Post by 70_F100 »
fordman wrote:yes it is illegal to use a compression fitting on brake lines. that is why they say they wont sell them. but if you tell them your not workign on brakes for a truck they cant say that. you tell them its for something else.
:yt:
onetuford
Post by onetuford »
Wow I never knew that untill today. I used to use them quite often for brake line repairs. The parts store I bought them from knew that too. I don't disagree with the reasoning. The two nuts and union were less expensive than the compression fitting anyway.
70_F100
Post by 70_F100 »
There is a reason for this.
Compression fittings are not designed to handle the high pressures exerted on brake hydraulics.
Mach428
Post by Mach428 »
I agree with 70 F100. Do NOT use compression fittings. Either replace the line you are trying to connect with one full line or use a double flaring tool to connect with flared fittings.
onetuford
Post by onetuford »
onetuford wrote: I was able to get a union and some nuts since I own a flaring tool. I prefer to do it that way, but never did in the past.
