just a quick sway bar question
nolan in blaine
Post by nolan in blaine »
i know that i want one off a 73-79 pickup. I was just wondering if it has to be off a 2wd? And can it be off a van?
mine is a 70 2wd F100
nolan in blaine
Re: just a quick sway bar question
i guess the big question is. will it fit?
nolan in blaine
yes just wanting to know if it will fit
nolan in blaine
mrtleavitt
Post by mrtleavitt »
I believe the actual sway bar is a little different. If I remember correctly I grabbed a sway bar from a truck but got all the other brackets and such from a van. The reason was that the truck was covered in grease and the van was very clean.
1969 F100 428 with T19, 3.00 9inch 31 spline w/ Detroit Trutrac, '74 frame swap successful!
http://s43.photobucket.com/albums/e356/mrtleavitt/
mrsnicks
Post by mrsnicks »
You will definitely want a 2wd as a 4X4 has a solid front axle and does not use Ibeams. I'm not sure about the van or not. I would think as long as it uses ibeams it should work.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
nolan in blaine
So i finally found a sway-bar off a 79 F250. The problem is i dont see a place for the sway bar links to bolt to on my F100. What do you guys use?
nolan in blaine
nolan in blaine
oh i see im missing the bracket.... damn it all....
nolan in blaine
you have to have all the brackets in order to use it. here is how they coem off and go back together. http://www.fordification.com/tech/image ... ematic.gif
