Help With Shocks
Help With Shocks
I need to change the shocks on my 68 f100 and was wondering what you guys would suggest I should go with? Also should I look into changing the Coil Spring? The truck seems to have a slight lean towards the drivers side.
Thanks for your help.
Tico
Tico
- BobbyFord
Re: Help With Shocks
I like KYB shocks.
Lean could be caused by leaf or front coil. It's best to measure all four corners if you have a lean concern.
- 69rangerf100
i just installed some Gabriel load carriers shocks both front and back and they really mad a difference than the old worn out shocks. i will grab a few pics and post them for you. for the coil springs wouldnt be a bad idea i also replaced them with som moog coils
David
- 69rangerf100
here is the front
here is the rear
here is the rear
David
- 1971ford
- 69rangerf100
yep they should you supplied them to me thanks1971ford wrote:Those coils look oddly familiar
David
- BobbyFord
Wow, those are some serious u-bolts!!
- 69rangerf100
yeah i havent put the helper springs back on yet so that is why their is so much room on them
David
- 1971ford
It is awesome to see them being used and not sitting in my garage!!!69rangerf100 wrote:yep they should you supplied them to me thanks1971ford wrote:Those coils look oddly familiar
-Ryan
could another shock be installed on that front shock mount.......if you created a lower bracket???????I asked this question on the .net site for dentsides but no response.................I have a set of these same combination shock/coil towers from my 2wd and wanted to replace the separate coil and shock towers on my 4wd ................I know it would be BEST to stagger the shocks but I want to make use of what i already have. somebody please respond
- 69rangerf100
yes it is possible i am still kicking me for not buying the i beams that were on the truck that i pulled my new cab off of. ford made factory i beams that had the extra front lower mounts on the for the HD frontendsgetjad wrote:could another shock be installed on that front shock mount.......if you created a lower bracket???????I asked this question on the .net site for dentsides but no response.................I have a set of these same combination shock/coil towers from my 2wd and wanted to replace the separate coil and shock towers on my 4wd ................I know it would be BEST to stagger the shocks but I want to make use of what i already have. somebody please respond
David
well if you could find the identicle lower bracket as you have already it seems you could just reverse them and blot it up as a sandwich on the I beam. wont work for me because the truck mine is going on is 4wd and not I beam set up. yours looks easy.
- 69rangerf100
the only thing that i can think of is make a template of your lower shock mounts and get them cut out of som high strength steel plates and weld them on
David
