Tire Pressures
- nikon4u
Tire Pressures
What is the official recomended tire pressure for a stock 67 f100?
I just got my web site up! Check it out!
http://www.Handyman-for-rent.com
"If it ain't broke, don't lend it"
--Red Green
http://www.fordification.com/galleries/ ... ?cat=10491
--Red Green
re: Tire Pressures
That depends entirely on what kind of tires you're using. The recommended rating should be on the sidewall. I could give you the factory specs, but those were for older bias-ply tires and I doubt you're still running those. Modern radials have lower pressures. Just take a look at your tire sidewalls and see what the manufacturer suggests.
