2002 F-250 wheels on a 1971 F-250 will they fit?
1971 Farmer-250
Post by 1971 Farmer-250 »
Are the bolt patters the same on a 2002 and 1972 F250 8 lug wheel? Are there any spacing issues anyone is aware of? Looking to buy different wheels for my truck and I don't know what is compatible.
Thanks,
Erny
1971 F-250 CS 390ci AT Work Truck and Trailer Hauler
1970 Mustang Coupe 5.0 EFI AOD Resto Rod and Trailer Queen
1955 Triumph Tiger T-110 Weekend Bobber
Caseys71
Re: 2002 F-250 wheels on a 1971 F-250 will they fit?
Post by Caseys71 »
I believe that the 3/4 ton pattern was only the same as our trucks up to '97 but I could be wrong.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
fireguywtc
Post by fireguywtc »
You are correct Casey, the bolt pattern is different (larger) on the 99+ trucks. You will have to get some sort of adaptor plate to adapt the differnt lug pattern if you really want them to work.
Bill
1971 Farmer-250
Thanks Casey & Fire Guy. I guess the search continues, I'm not trying to use an adapter plate. I've heard horror stories of those breaking off at high speeds or heavy use.
quantumleap
Post by quantumleap »
are the adapter plates or spacers really that bad?
Daniel--67' reg cab black shortbed/fe/4spd/ford 9
