15x8 wheels
element7878
15x8 wheels
Post by element7878 »
I was thinking about getting 15x8 wheels all the way around my truck. Any suggestions or wheel setup pictures? I really like the cragar nomad II's...
1967 ford f100 Shortbed
Ford 360,edelbrock intake,holly 4bbl 600,rv cam
San Antonio, Texas
Quick69
Re: 15x8 wheels
Post by Quick69 »
I just picked up some steel 15x8's to run on the back of mine, I think they look great on bump sides
1971 F100 Ranger XLT
302/C4/3.25
3/4 homemade drop
cdeal28078
Re: 15x8 wheels
Post by cdeal28078 »
In order for the rear wheels not to look like they are too skinny you need to run wider wheels in the back than the front. I used to run 10" wheels and 50's in the back with 8" wheels in the front and liked the looks a lot. Got rid of those years ago and am running stock 80-90"s aluminum wheels and like them but wish the wheels all had the same looks front to back
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
RTG_RACING
Re: 15x8 wheels
Post by RTG_RACING »
swap in a 73 and up rear and the front and rear will be the same. Just move the spring perches and shock mounts. Not much work at all.
mrtleavitt
Re: 15x8 wheels
Post by mrtleavitt »
Here's my 15x8 rims all the way around with 31x10.50.
1969 F100 428 with T19, 3.00 9inch 31 spline w/ Detroit Trutrac, '74 frame swap successful!
http://s43.photobucket.com/albums/e356/mrtleavitt/
