Since I am replacing my '67 drum brakes with '79 disc brakes I am guessing it's safe to order new r/a and t/a bushings for a '79? It appears they are the same fit but I want to make sure.
Does it matter what year bump stops I order?
Where is a good place to get suspension parts?
I hope I don't drive you people crazy with all my amatuer questions, I'm winging it but still trying to maintain a quality job.
Front End Bushings
Front End Bushings
'67 352 3spd 3.25 9" Custom Cab
'92 Mercury Cougar
http://www.fordification.com/galleries/ ... ?pos=-3222
Re: Front End Bushings
sub'd for answer
'68 F100:
70's model 289 and steering column. Column shifted C4. 9" rearend w/unknown gearing.
Got a little something special in the works to give it some go.
After looking at the NPD website (which has great exploded diagrams) I found that the part numbers are the same for '67 and '79 pivot axle bushings and trailing arm bushings. The bump stops are not the same number. I am going to assume that if I order a bump stop for a '67 I should be ok.
<slaps forehead> I just had a news flash, it's all the same except for the kingpins,...geez, nevermind.
'92 Mercury Cougar
