1 ton front end on my '71 f250
1971ford
Post by 1971ford »
I have the 1 ton 1" kingpin mega huge front I-beam setup on the restored '69 chassis in my side yard. I am taking it off tomorrow and I'm going to bend it/plate it to fix camber for the race truck (bent the 3/4 ton beams).
I'll use the steering linkage, radius arms, and the i-beams.
One problem i see right now, is lug size. The lugs on the 1 ton discs are MASSIVE. I had to buy 4 lug nuts (2 for each wheel to roll it around) and they don't even fit in my aluminum rims. What are my options here? I need the 1 ton beams but i also need the smaller 3/4 ton lugs.
Ideas??
-Ryan
Re: 1 ton front end on my '71 f250
wheel adapters?
1971ford
Post by 1971ford »
I'd like to stick with stock parts. I can't just swap discs over can I? And i can't punch out the lugs and put smaller ones in?
-Ryan
i dont think yo ucan change the lug sizes. i dont know about discs that fit.
