Backing plate on ibeams for drum brakes
69rangerf100
Post by 69rangerf100 »
ok so i have removed all the bolts and nuts from the backing plate except the 2 bolts on the bottom of plate. these are stuck and i cant get them to break lose any ideas on how i can get the backing plate off so that i can get it off
David
Re: Backing plate on ibeams for drum brakes
soaking the thrreads in penetrating oil. or heat the spndles around the threads.
hazelnut
Post by hazelnut »
Ive had luck with heating the bolt good and hot and letting it cool off few hours before trying to pull out, give it a shot of penetrat before trying to turn. Also like fordman said and when youve heated the spendle around the treads put a piece of ice on the bolt to cool it and make it contract and it should turn out for you.
