How big a hydraulic press?
Discuss your workshop and related equipment
1972F100
Post by 1972F100 »
First job it is needed for is to rebuild my recently acquired t18.
Let's just assume I'll need one for the common jobs in fixing up our bumps.
Is this big enough? How big is big enough?
http://www.harborfreight.com/cpi/ctaf/d ... umber=4711
Douglas
Re: How big a hydraulic press?
I have a similar HF press, except that it's a 12-ton, for only a few bucks more. I'd suggest getting that one instead.
http://www.harborfreight.com/cpi/ctaf/D ... mber=33497
1972F100
Post by 1972F100 »
Thanks Keith. Good advice. I see the 12 ton for 130 bucks.
eggman918
Post by eggman918 »
:yt:
12 ton is a nice size for a home shop,it will do most bearings/bushings.In my years in the machine shop the press scrapped more parts
than the other machines combined,the 12 ton press is not as easy to break things as it is in a larger press.
In general if it does not move with 12 tons it needs heat or a different setup in the press.
Be careful when you press on shafts if they are not in straight or your setup fails/shifts you can end up WEARING it,they come out like a bullet!
:2cents:
Steve
stephen44
Post by stephen44 »
would this size do king pins ?
- Stephen
thanks
Stephen
Depends on the kingpin and the prior maintenance (or lack thereof) to it. Many folks have been able to remove kingpins with nothing more than a ballpeen hammer and large punch, so in those cases the press would work great. Then again, I've heard of instances where removing kingpins stressed a 25-ton press. But I'd say in most cases, the 12-ton would work fine. :thup:
i have had to cut king pins out with a torch on some and 1 of them i slid out with only my fingers.
71PA_Highboy
Post by 71PA_Highboy »
FORDification wrote:I have a similar HF press, except that it's a 12-ton, for only a few bucks more. I'd suggest getting that one instead.
be careful with these.
The arbor plates are usually cast iron and are known to shatter under a load.
If you buy one, hit your local metal yard and buy yourself 2 pieces of 1"x3" CR 1080 and use them to fully support anything you are working on.
http://www.pirate4x4.com/forum/showthread.php?t=849831
Safety FIRST!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
stephen44
Post by stephen44 »
wow - did you see that guy's face :eek:
thanks
Stephen
eggman918
Post by eggman918 »
Safety first!!! the press is far more dangerous than it appears at first glance,to both parts and people :2cents:
Steve
1972F100
Post by 1972F100 »
Thanks guys for your input...I'll have to think about the arbor plates.
Sometimes it seems HF is good for some stuff, but not so for others. For example, I got my engine hoist from there. It works, but it slowly drops the boom, even when not under load. I've bled the cam, checked the fluid level and made sure everything was tight, looking to prevent leaks. So, it works, but I can't use it for long periods without jacking it back up.
Hand tools, Sears Craftsman work for me.
