Can anyone identify these tires?
I am trying to find what size and brand they might be.
Re: Can anyone identify these tires?
the name and numbers should be on them. either on the inside of the tire or ther outside of the tire.
Its not my truck and I do not know whose it is so I do not have access to them.
Those appear to be military GOODYEARs 16.5's
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
- zakt
If a F250 for sure 16.5 steel stock rims (hubcaps look stock also) here is my 72 with 33x12.50x16.5 so thinking those might be 35" tires
1972 Ford F350 crewcab
- tybob81
They look like military 16.5's. Like whats on the hummer.
- convincor
thinking they're older Ground Hogs. the older didn't have the tread as far down the sidewall.
probably 35-36"
http://www.4wheelparts.com/Tires/Denman ... 13&t_s=162
these were 35" BFG's on mine.
probably 35-36"
"Still Plays With Trucks"
- zakt
I thought they might be the ground hawg also but if you look close at the side lug it has (2) lines down toward the center and the hawgs have (1) so not those
They sure do look like those Ground Hawgs. If they are, then they have some miles on them.convincor wrote:thinking they're older Ground Hogs. the older didn't have the tread as far down the sidewall.
probably 35-36"
What width are your 35's?
- convincor
there were 35/12.5/16.5
here's another angle
- Orange Beezy
Dick Cepeks ?
I WILL KEEP MY GUNS<MY FREEDOM AND MY MONEY!
YOU CAN KEEP THE "CHANGE"!
1968 FORD F250 CC LWB 390 C6 w/1972 front disc brakes
1965 Ford Fastback 2+2 (SOLD)
- zakt
36x14.50R15LT, Ground Hawg RadialLoad Range CMax Load = 2910Tread Depth = 21/32Overall Diameter = 36.0 in.Black Sidewall
36x14.50R16.5LT, Ground Hawg RadialLoad Range EMax Load = 3640Tread Depth = 21/32Overall Diameter = 36.0 in.Black Sidewall
http://intercotire.com/tires.php?id=4&g=1
Ground Hawg
The Ground Hawg has a unique tread pattern that's designed for slinging mud. The diagonal lugs use a directional pattern optimized for deep mud and sand. The Ground Hawg is a Bias tire. If you're interested in a Radial version of the Ground Hawg, check out the Ground Hawg II.
- convincor
Anyone else noticed the GH's are now made by Interco who makes the SuperSwampers.
They used to be made by Denman.
Which I think is on that truck.(the old GH's)
edit: on second thought, the Ground Hog letters were huge. Can't see them on those.
This information was passed along to me. I understand the truck is from Vancouver, BC too.
Power King
Super Traction
9.00 - 16LT
Power King
Super Traction
9.00 - 16LT
If you're looking for the classic truck tire look, try Univeral Universal Vintage Tires or Specialty Tires of America. They have similar tires.
Kevyn
1972 F-250 4x4, 390, Dana 44, 24, 60
