front axle vent routing
d44 high pinion. this is D4 axle i think. thats what the tag on the cover says. as well as the ratio. 3.50 where does the rubber tube or what ever its made of route to? it starts at the top of the axle and goes to where? i fixed the rear vent tube today and want to fix the front one tomorrom. i fear i may have already gotten water in both of them this weekend. the rear axle tube runs in basically the same as a 2wd does. but the front i have no idea where it runs to or clips up at.
Re: front axle vent routing
so no pictures or advise as to where to hook this thing to? how high up should it go? i want to be able to cross the creek and not get water in the front axle.
It goes high inside the frame then loops down.
There was a clip that held the hose to the frame.
