PS Questions
Mach428
PS Questions
Post by Mach428 »
I have two questions reqarding the conversion of MS to PS. First, does the manual steering box and the Ford PS box use the same pitman arm? Can I just remove the arm from the manual steering box and intsall it on the Ford PS box?
Also, same question regarding the MS rag joint coupling on a PS box. Are they the same?
Thanks all
killakobra
Re: PS Questions
Post by killakobra »
Mach428 wrote:I have two questions reqarding the conversion of MS to PS. First, does the manual steering box and the Ford PS box use the same pitman arm? Can I just remove the arm from the manual steering box and intsall it on the Ford PS box?
Thanks all
i think the rag joint it's self is the same but i don't know if you can use the same column due to length different. i don't know about the pitman arm. sorry.
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
Re: PS Questions
the pitman arms are the same. the rag joint will work fine. depending on the column center shaft used.
Mach428
Re: PS Questions
Post by Mach428 »
Thanks for the info guys
