Messed up Rear Brakes
- fordboy69
I'm redoing the rear brakes on my 69 f100. One side didn't have anything except the wheel cylinder and on the other side most of the springs and adjuster are broken. Does anyone have the rear brake diagram that shows where everthing goes? Also there is a knob just above the wheel cylinder that some springs hook up to that is sheared off. Can you change this or what? Thanks.
-1969 F100 360FE
-1970 F250 (Parts Truck)
- fordboy69
Re: Messed up Rear Brakes
I ordered the right springs but I just started putting things together. Heres what I have on the other side.
-1969 F100 360FE
- SteveC
http://www.fordification.com/tech/schematics_b.htm there here for the diagrams
and i believe and don't quote me on it but i think you need to change the backing plate
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
As for that sheared-off pin...yes, you're going to have to replace that backing plate. That pin cannot be removed/replaced.
- fordboy69
Ahh there we go thanks for the diagram. So would I have to change the anchor pin plate since the knob at the end is sheared off?
-1969 F100 360FE
FORDification wrote:...As for that sheared-off pin...yes, you're going to have to replace that backing plate. That pin cannot be removed/replaced.
- fordboy69
Sorry I didn't see that writing under the diagram. Thanks for the help.
-1969 F100 360FE
- fordboy69
I have a f250 parts truck. Would brake components from a 3/4 ton work on my f100?
-1969 F100 360FE
No, they're completely different.
- flyboy2610
Fordboy, where do you live?
I have a trailer made from a F100, but my truck is an F250. I'd be willing to swap rear ends with you if you aren't too far.
- fordboy69
Thanks but Im in Winnipeg, Manitoba. I might be able to get some parts this Saturday I dont know yet. That sucks that the f250 is different I thought they might be.
-1969 F100 360FE
- flyboy2610
Yea, that's a bit far. Good luck with your parts!fordboy69 wrote:Thanks but Im in Winnipeg, Manitoba.
i've been to manitoba when i was a kid. i have proof someplace.
- fordboy69
Where in manitoba did you visit?
-1969 F100 360FE
i dont remember i have a picture of me hanging from a sign that says welcome to manitoba. it was just voer the border from norht dakota. i will try and find the picture.
