furnitureguy-123 wrote:
Is there a reliable way of checking wear in the king pins b4 you tear everything apart?
In my experience...
King pins aren't easy to check like ball joints are. :/
There's play "up and down" that's tough to check too.
They will fool you into thinking they are good. BTDT
You've got "wobble wobble wobble". ;)
Just friggin change 'em, you'll be glad you did. ;)
...replacing the king pins and their bearings is a
-key- part of the "wobble wobble wobble fix". :)
You can do it. :)
Just do it. :)
Between the time I spent carefully typing out posts for
you and you working hard at trying to -not- do the job...
...the job could have been done already! Believe it? ;)
Alvin in AZ
ps- how old are you?
