I have removed them from trucks with ''A'' arms but not from an "I" beam front end.
I also noticed that the top of the coil is wound smaller to fit into the top of the tower,so should i cut the coil from the bottom.
Thanks guys.
HillbillyDelux wrote:
does cutting the coil affect the ride any?
By cutting off 2 coils, will the truck shop still be able to bend the beam back to the correct caster? How much will this lower the truck? ThanksFORDification wrote:I'd suggest using an angle grinder with a cut-off wheel, to minimize heat buildup. I suppose you could get by with a hacksaw...if you've got biceps like Paul Bunyan, that is. Using a torch will transfer too much heat into the coil, which will ruin the temper.
The more you cut off the coil, the stiffer it will become....and as mentioned, the more the caster will be messed up. And the only way to correct the camber is to have a truck shop cold-bend the I-beams.
In the picture it would appear that 2 coils were removed. Now since the second round removes far more drop (greater spacing between coils) than the first round, it would appear that removing one coil would only result in about half as much drop as the second coil.FORDification wrote:I'd suggest using an angle grinder with a cut-off wheel, to minimize heat buildup. I suppose you could get by with a hacksaw...if you've got biceps like Paul Bunyan, that is. Using a torch will transfer too much heat into the coil, which will ruin the temper.
