What is this on my holley carb?
JMcTurnan
Post by JMcTurnan »
Whats this little plastic piece on my carb? It broke and slips off, what is it called and where do I get one?
Sorry for crap of a pic
Alvin in AZ
Re: What is this on my holley carb?
Post by Alvin in AZ »
That whole thing has something to do with choke opening when
the engine has to have it open no matter what the weather is.
...or is the other way around? LOL :)
It's been a while since I was afflicted-with and cured-of all choke problems. ;)
http://www.panix.com/~alvinj/file12/choke1.jpg
Alvin in AZ
DuckRyder
Post by DuckRyder »
Are you sure that is a Holley?
That is a choke pull off (aka vacumme break). Its function is to allow the choke plate to be fully closed during engine start but as soon as the engine starts it pulls the choke plate open. (hence the name pull off).
JMcTurnan
Post by JMcTurnan »
Yea, it says it is.
willowbilly3
Post by willowbilly3 »
For any Holley parts you will need the (list) numbers, usually on the choke air horn. Either go to your local parts store or go online. You might try to google "Holley parts" or Holley Carburator" I bet Summit can fix you up. I have got parts right from Holley engineering if it is something not normally serviced by dealers. Now the question that begs answering is how the heck did you bust that part?
fitzwell
Post by fitzwell »
looks like a choke pull-off from a late 60's ford 2100
peanutman
Post by peanutman »
:yt: That's not a holley carb, thats an autolite.
JMcTurnan
Post by JMcTurnan »
Your right, some fool had a sticker on there. Its f'ing up on me, I need a new vaccum break, know where to get one? Im having lotsa trouble with it. I fixed one part, but now its back firing pretty bad.
now since you have two carbs the same isnt one of them good for parts? i fnot try the parts stores. ebay and the partswanted section. i do not have one.
willowbilly3
How do you keep breaking stuff?
JMcTurnan
Post by JMcTurnan »
Well there not exactly the same, one doesnt have that vaccum break. This carb was broken from the beggining, and Im just trying to rebuild it, I need to get one of those and I believe it should be fixed if that would cause backfires? It was broken when I bought it, this is I guess the original carb on the 68' fairlane motor I have in it, the other one that I broke the ear off is a 80 f150 with 302.
390F100
Post by 390F100 »
My :2cents: go buy a new carb, you can get a reman 2bbl for 100 bucks and a new Edelbrock for 200 plus or minus a few bucks...
390
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
backfiring through the carb is usually a timing issue. if it backfires with both carbs then it hass to be something other than two bad carbs. the problem is still exsiting with something other than either carb if both carb backfire.
390F100
Post by 390F100 »
:yt: Good Call
390
2007 Suzuki S40 650
JMcTurnan
Post by JMcTurnan »
It didn't do it on the first one, so I'm not 100% sure, but Ill check the timing out. Unfortunately I would buy a carb, but I have no money at all, so Im scrounging up a few bucks to see If I can get my truck running. I got a 351w Im getting this week, it just needs a new accellerator pump and gasket on the carb, Ill just fix it. But I dont want to just toss away the old carbs If I can get my moneys worth out of them.
