250 frame
killakobra
250 frame
Post by killakobra »
my 72 f100 sports custom is sitting on a 70 f250 frame and the front cross member is smaller than the one on my 69 f100 frame.
here's a picture of the 70 frame
was it standard for 250's to be set up like this? and why would the cross member be smaller?
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
fireguywtc
Re: 250 frame
Post by fireguywtc »
mine is wider but it is a 67 model. I dont know what is more normal, large or small.
http://i439.photobucket.com/albums/qq11 ... 1238546441
Bill
Re: 250 frame
they are different because of heavy dutyness of the two sizes of trucks.
killakobra
Re: 250 frame
fordman wrote:they are different because of heavy dutyness of the two sizes of trucks.
but you would think that the f250 would have the heavier crossmember?
ka_jd7and1
Re: 250 frame
Post by ka_jd7and1 »
I'm taking a blind stab at it, but would the original engine/trans combo have anything to do with it?
03 Chevy S10 - the daily driver
68 Ford F100 longbed - the tow pig / TLC project
78 Chevy Impala - the race car
I'm sorry if I ask lots of questions, there's just a lot of stuff I don't know (yet).
mrtleavitt
Re: 250 frame
Post by mrtleavitt »
In my experience '67-'69 had a wider crossmember than '70-'72. My bro has a '70 F100 Shortbed with a small cross member and my '69 F100 shortbed has the larger cross member. I don't know why but everyhting else is the same on the two trucks minus the rear shock mounts.
killakobra
Re: 250 frame
mrtleavitt wrote:In my experience '67-'69 had a wider crossmember than '70-'72. My bro has a '70 F100 Shortbed with a small cross member and my '69 F100 shortbed has the larger cross member. I don't know why but everyhting else is the same on the two trucks minus the rear shock mounts.
when i first saw the rear shock mounts i thought the frame was mangled and then i noticed it was symmetrical. i guess they cut down on the cross member to save weight.
ka_jd7and1 wrote:I'm taking a blind stab at it, but would the original engine/trans combo have anything to do with it?
original engine was a 390 so i doubt that would call for a small x member
Re: 250 frame
which way is it smaller? front to back top to bottom? you are saying it is narrower front to back?
killakobra
Re: 250 frame
fordman wrote:which way is it smaller? front to back top to bottom? you are saying it is narrower front to back?
it is smaller front to back than the cross member on my '69 f100
Re: 250 frame
measure it fo rme. i am interested in seeing how small it is.
killakobra
Re: 250 frame
fordman wrote:measure it fo rme. i am interested in seeing how small it is.
the cross member is 9 1/2" opposed to 12" on my stepside.
Re: 250 frame
i was out looking at my 70 F100 friday morning and the crossmember looked the same size in your pic. i only looked at where it sat compared to the upper spring perches. is your larger crossmember just as wide as hte spring perches? does it sit even with the front of the spring perch where the one in that pic sits just back some from the front of the spring perch?
killakobra
Re: 250 frame
fordman wrote:i was out looking at my 70 F100 friday morning and the crossmember looked the same size in your pic. i only looked at where it sat compared to the upper spring perches. is your larger crossmember just as wide as hte spring perches? does it sit even with the front of the spring perch where the one in that pic sits just back some from the front of the spring perch?
here is a picture of the wide cross member. they sit slightly infront of the spring perches and are slightly wider than the perches (not including the lip)
Re: 250 frame
on the front drivers side of the frame rail right below where the core support bolt on is a part number on the frame. what is the part number? maybe this is a model change to the frame. having a wider or narrower crossmember.
Redcap
Re: 250 frame
Post by Redcap »
I wonder how much thicker the steel on the narrow F250 crossmember is?
