power steering modification question
- 69rangerf100
ok i have read the thread several time about doing the conversion from MS to PS. the steering gear box that i have is a FoMoCo box. i have my original steering column that has the three on the tree for MS. what i am not clear on is if with the FoMoCo box is wheitheror not i have to shorten the column? any input would be greatly appreciated.
David
Re: power steering modification question
the manual three speed won't work with a ford box. it is too long. the shifter arrms will hit t he firewall and the bracket under the dash wont bolt up. it will be outof place.
- 69rangerf100
ok, new question what are my options for getting a working column that will still have the column shift?
David
for a three speed? narrow to none. those are your chances fo rfinding a power steering 3 speed column.
- 69rangerf100
ok so i guess my only option is to put a floor shift in and find a steering column for a munual from a factory floor shift truck that had PS right
David
- FreakysFords
69rangerf100 wrote:ok so i guess my only option is to put a floor shift in and find a steering column for a munual from a factory floor shift truck that had PS right
I have a PS 3sp column in my 69 Ranger that'll be coming out this coming weekend. Someone's removed the shift lever, so I'm sure it'd need rebuilt, but that's no bid deal.
Darlin 69 Ranger 390 4v, PS, DS II, disc front, 3G alternator, 67 mirror.
- 69rangerf100
i have heard that there are some pretty good salvage yards out in alabama. have you ever run across any 3 spd PS columns out there
David
- FreakysFords
Yup. I butchered one not too long ago for my Niece's go buggy.
You also have a good U Pull It not far from you.
- 69rangerf100
really were at the only ones that i know of is in norcross and conley, ga. dont really want to drive to the otherside of atlanta and come up empty handed
David
- 69rangerf100
thanks for the advice peanutman. i am no where near being ready to put my truck on the road. i am still in the tear down and body work stage so i have all the time in the world right now.
David
- 69rangerf100
ok new question what is the length of a power steering column for a ford gear box?
David
- convincor
dimensions can be found here- http://www.fordification.com/steering-column.htm
"Still Plays With Trucks"
