Rust Bullet Question
CO684X4
Post by CO684X4 »
I am looking at ordering Rust bullet for my truck today. Just have one question though. I want to go with the Rust Bullet Black Shell. Now my question is can this be used by itself or does it need to be used as a top coat over the regular rust bullet? From my understanding it can be used by itself
http://www.rustbullet.com/ProductCart/p ... roduct=424
67 ford f100s rule
Post by 67 ford f100s rule »
no it doesnt need to be used to top the regular rust bullet.In the description I think it says can be applied over painted or unpainted surfaces. though i think you would get better protection from coating over regular rust bullet.I hope that answers your question
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
CO684X4
Post by CO684X4 »
so it can be used by itself then?
67 ford f100s rule
Im guessin yeah it can be used by itself.
Jeff Penland
mljjones67
Post by mljjones67 »
Yes it can be used by itself. It has UV protection. Por 15 doesn't.
mljjones67
it should work great! That is what I will be using. Just remember it is all in the prep work. Personally I am going to have my frame sandblasted to get rid of the rust. Then I am going to hit the whole thing in some metal prep/degreaser.
CO684X4
Post by CO684X4 »
i was planing on having it blasted to get all the crap off.
mljjones67
Here is the application guide. How much you going to get?
http://rustbullet.com/Application.htm
CO684X4
Post by CO684X4 »
I was thinking 2 or 3 quarts. I will be spraying it with an HVLP gun. Want to do the core support, inner fenders, under cab, under bed, frame, axle housings, radius arms and all the brackets that bolt to the frame.
mljjones67
I just put in a small order for the six 4 0z and a gallon of the metal prep stuff. Free shipping. Only cost me $85.00
