Bump Rust Map
smclaren
Bump Rust Map
Post by smclaren »
Hi Guys
I live right on the coast, and most vehicles here get destroyed sooner or later from rust. http://images.google.com.au/images?sour ... a=N&tab=wi
I bought my bump from a very dry part of Australia, and now that it's on the coast (and not garaged) its gonna get attacked by salt air ... BIG TIME.
So .. I have started the prevention process using fish-oil and that's great ... but my question is .... where in your opinion do bumps tend to rust the most?
I have pretty much bathed the vehicle in fish-oil, but I want to make sure I have got the key area's. ( http://www.septone.com.au/detail.asp?it ... page_num=1 )
Because I speak the 'Queens english' and you don't :lol: , a photo with arrows would help me understand where you mean... especially if its you responding, rjewkes. :evil:
Thanks Guys
Steve
Image Steve - Caloundra, QLD, Australia Image
1969 F100 4x2, RHD, Base Model, 240ci, 4sp, Dealer Canopy, No Bloody Radio.
ford4x4fun
Post by ford4x4fun »
What is fish oil :? Not to change the topic :? And being from Eastern KY, I don't think there is such a thing as the Queens English :lol: Just my English!!
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
ford4x4fun
Nevermind just read your thread on the other stop rust post, got your link :thup:
US ARMY Retired
re: Bump Rust Map
By far, the worst areas include:
- the front cab mounts and floorpans
- the rear cab corners
- the side-to-side cab support brace (rusts at each end, where it attaches to the rocker panel)
- the driprail area
- the inner fenderwells, at the hinge attachment point
I'd say about a vast majority of regularly-driven trucks have some cancer in all of these areas. However, virtually any place that will allow moisture to collect and not immediately dry out will cause rust, and can include the front of the rocker panel area (at the base of the door post), the front of the hood and the bottom/rear of each front fender. And of course, when the caulking in the bed seam starts coming loose, it also holds moisture in, causing rust. However, the bed seam actually accumulate moisture from the back side, where the top and lower panels are spotwelded together.
Also, if a truck has ever had undercoating installed, by now it's probably coming loose, so any place where it's loose will hold moisture in and rust out the surrounding area.
rjewkes
Post by rjewkes »
I have seen lots of rust just below the Tail lights on the bed end caps. perhaps better than re-applying fish oil as suggested by the manifacturer, Some por-15 on the backside of these pannels?
seattle67
re: Bump Rust Map
Post by seattle67 »
There are two places where I mine has rusted through, Keith hit on one of those, the rear cab corners. The other spot for me is the bottom edge of both doors.
Dan
"I plan to start procastinating immediately"
rjewkes
Post by rjewkes »
my current one as all of them. and lets not forgrt the core support around the hinges.
71Ford100
re: Bump Rust Map
Post by 71Ford100 »
The rad support in my area has a tendency to rust out along the bottom lip.
Lance Peters
SteveC
re: Bump Rust Map
Post by SteveC »
about every place you guys mentioned was rusted on that 70 i junked i stomped on the floor board going after a mouse and my foot went through the floor alone with the floor matt :eek: that and after i took out the rear bolts holding the cab down i took a 2x4 and could easily roll the cab onto its back to be hauled up on the roll back truck
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
garner67
Re: re: Bump Rust Map
Post by garner67 »
FORDification wrote:By far, the worst areas include:
- the driprail area
My biggest rust challenge to fix is my drip rail area. Make sure you put a lot of that Aussie fish oil on that area! :)
I recently purchased a new cab that was hit on the lower passenger door, and I plan to cut off the entire roof to fix my roof. It's going to be a big job... well, for me.
71 F100
Mike
garner67
Post by garner67 »
- the driprail area
71 F100
Mike
nmu91
Bump Rust Map/repair
Post by nmu91 »
How did you end up repairing the side-to-side cab supprt brace? Did you just weld in a patch? Did you remove one from another truck? I believe this isn't a part that you can just purchase a replacement for?! :o
I still have to get started on my truck.
Thanks.
