From a 1978, Ford saginaw box, same year PS pump.
I know Ford would have recomended Type F ATF and barring suggestions that sound better, that is what I will probably use.
Any idea how many quarts I need?
Powersteering fluid capacity and type, opinions and advice?
re: Powersteering fluid capacity and type, opinions and advi
if it was me, and a new sytem...Royal Purple Synthetic. Be aware, it this is used pump/box combo, you will find any leaks. If you don't want to use synthetic fluid,or it IS a used system Valvoline Max life fluid is good quality stuff. i'd get 2 quarts just to start with. Remember to take the wheel almost lock to lock (slowly) 5-10 times, to bleed the air out of it.
just my
just my
I've used any kinda power steering fluid or ATF in mine, but it leaks so bad anyhow it couldn't possibly matter.
