front springs
front springs
just wondering why my f250 and the f100 i just got rid of have 9 coils in the springs and the original springs from my fisrt bump had 11 coils. both f100's were the same so i figured the f250 would of had more. are the springs on the 250 the right ones?
re: front springs
It's more the wire diameter that matters than the number of coils. When it's thicker, you don't need as many coils...and it's a lot stiffer. It would all depend on the GVW rating of the truck.
re: front springs
i looked at that as well. the ones with 11 coils were 2 3/4 in while the ones with 9 coils were 2 1/2 in. should i put the 11 coil on my f250?
re: front springs
the 250 still has the 9 coils on it. i still have the 11 coils from the 70 f100. those are the ones that are thicker in diameter. just wondering if those would be better.
- Wes
Keith meant the diameter of the steel used to make the spring, not the diameter of the spring. I would use the f250 springs in the f250
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
re: front springs
The more coils you have, the softer the spring rate. Fewer coils mean stiffer spring.
Unless you're going to be doing a lot of very heavy hauling/towing, I'd go with the softer spring. There really isn't THAT much difference, but it won't ride so harsh in front by choosing the spring with more coils. Just my
