lift kit?
lift kit?
i would like to lift my 68cs about 4 inches. i know its 2wd but think it would look good. has anyone here done this? where did you get the lift kit from? thanks
- Thunderfoot
re: lift kit?
Same answer I left on the other thread... Check this site out http://www.autofab.com/5lift.htm
Shayne
re: lift kit?
what is the differance in a lift and a body lift?
- Thunderfoot
re: lift kit?
A Body lift just raises the body up off the Frame where as a lift raises the Frame up from the axles.
Shayne
- averagef250
re: lift kit?
maybe i will just get a lift kit for it. rather spend a little more than have to jerry rig up my steering.
- Thunderfoot
Ok, time to school me on 4x4'saveragef250 wrote:You can't body lift a 2wd without major steering work.
Shayne
- averagef250
- Thunderfoot
re: lift kit?
Ah, that makes sense then. Thanks
Shayne
- basketcase0302
re: lift kit?
hotrod,
Dustin's right about the 2WD steering, (I guess I never really looked the 2WD real close before now).
With the 2WD steering box aft of the front wheels it probably would be pretty tough.
Scroll down to look at the steering box:
http://www.fordification.com/powersteering.htm
I installed a custom body lift easily on my old style Bronco, (I lengthened the steering shaft by using 40K PSI crane tubing).
But the 4WD already had universal joints in place to easily correct the angle created by the lift.
Basketcase
Basketcase
- kilog55
Re: re: lift kit?
Thunderfoot wrote:2 threads with the same question.
WOw
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
