our rear fender wells wont take more than about 4" of back spacing. i had some 275/60r 17's on mine and they rubbed the inner fender wells. the wheels had 4" of b/s and the tire tread width was about 9" (goodyear eagle gt 2's). hope this helps.
wanting to buy a mercury tailgate! "the man who is swimming against the stream knows the strength of it".- woodrow wilson
Cool thanks.... Now lets go over lug patterns.... Cragar made a universal 5 hole pattern correct?
It will fit 5 on 4.5.......5 on 4.75 and 5 on 5 Correct?
You are both correct in your statements!!! the universals will not work you need the 5x5.5 bolt pattern unless you have adaptors or changed out the axles and front hubs to different pattern... Here is the info for the 15" Cragar, they do make a 5x5.5 - 8" and 10" wide wheel... http://www.cragarwheel.com/scripts/seri ... ries_61_08 this also list the backspacing of the wheels, the 10" have 4.25 so you may need to add a spacer if Ezer is correct on the 4"...
Shayne
