Staying logged in
- MaxKlinger
Staying logged in
I have to log in constantly to be able to use the forums! I'll log in to the forums, then when I find a thread I want to post on, it'll ask me to log in before I can post. Then when I hit the "Submit" button, it asks me to log in again and takes me back to a blank posting window. What's going on here?
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
re: Staying logged in
AOL and a few other Internet Service Providers constantly and frequently change the IP address assigned to you while you are actually online, rendering your session ID cookie useless. If you use AOL, you may need to log in to the Internet as you normally do and then switch to a different (non-AOL) browser before logging in to the forum. If you do not switch to a different browser, you will not be able to create and post messages, even when you have logged in successfully.
- flyboy2610
Netscape.
Log onto the internet like you always would. Then just minimize the AOL browser and start up a different one....like Netscape, Firefox, whatever...and surf the forums with that.
- MaxKlinger
I don't use AOL, ever. My computer is actually owned by my company, so I'm not allowed to put Firefox on it (otherwise I would have done so a long time ago).
Do you think my security settings have something to do with this?
Tony
Re: re: Staying logged in
If your hookup has alternating proxy hookups, then it's definitely causing a problem, similiar to what AOL is doing. Also, if your security settings are not allowing a session cookie to be saved on your computer, that'll do it.MaxKlinger wrote:I don't use AOL, ever. My computer is actually owned by my company, so I'm not allowed to put Firefox on it (otherwise I would have done so a long time ago).
Cookies are small data files stored by web sites on your computer so that they can save and read information such as your log-in. You can set your browser to accept or reject cookies based on various rules. Below are instructions for setting cookie rules on some of the major browsers - other browsers are likely to have similar options.
Internet Explorer (version 6.0)
From the Menu Bar select Tools, Internet Options …
Select the Privacy Tab
Pull the slider down to Medium
Click OK
FireFox 1
From the Menu Bar select Tools, Options...
Choose the Privacy icon (see below)
Click the + next to the Cookies option to open those options
Tick the box labelled "Allow sites to set cookies" and other options as desired
Click OK to finish
Mozilla and Netscape 7
From the Menu Bar select Edit, Preferences...
Select the Privacy & Security option
Select Cookies
Select either Allow cookies for the orginating web site only (this is the most secure option)
Internet Explorer (version 5.5)
Select the Security Tab
Select the Internet icon
Click on the Custom Level button, scroll down the list until Cookies appear and click on Enable for both cookie settings
Click OK and OK again
Netscape (based on version 4.08)
From the Menu select Edit, Preferences
Click on Advanced category
Under Cookies select Accept all cookies and click the OK button
AOL 9.0
From the AOL Toolbar, select Settings.
Select Internet [Web] Options
Select Use your Internet Explorer Settings to set advanced browser options.
Select the Privacy tab
Select Advanced
Deselect override automatic cookie handling button
Click OK to exit.
AOL 8.0
Select Preferences
Select Internet Properties (WWW)
Select Advanced
Click OK to exit.
AOL 7.0 with IE 6.x
Select Preferences
Select Advanced
Click OK to exit.
AOL 7.0 with IE 5.5
Select Preferences
Select the Security tab
Select the Custom Level tab
Under "Allow Cookies that are stored on your computer" click "Enable"
Under "Allow per-session cookies (not stored)" click "Enable"
Select OK, Yes you want to save the settings
AOL 6.0
Select Preferences
AOL 5.0
Go to My AOL
Pick WWW
Click the Security tab
Go to Custom Level
Scroll down to find Cookie
Click "Enable"
Click OK
AOL 4.0
Click on Preferences
Select on the WWW button
Click on the Advanced tab
Select the "Accept all cookies" checkbox
