Disks on my 67 F250
Kevin Harvey
Disks on my 67 F250
Post by Kevin Harvey »
I would like to put disk brakes on my 67 F250 - What donor truck(s) do I need to be looking for? Also, what do I need to take? Are any just a spindle swap or am I looking at ALL front suspension items (both axles/spindles/radius arms etc....) I am also thinking that the proportioning valve also needs to be swapped right? Does the master cylinder also need to be swapped - it is currently a power brake truck (factory) and I have a master cylinder with a large and small reservoir on it. Thanks Kevin
Kevin Harvey
Belleville ILL
here is most of the info you want to know.
http://www.fordification.com/discbrakes01.htm
and this tells what years to get that stuff from.
http://www.fordification.com/Ibeams&spindles.htm
Nausea
re: Disks on my 67 F250
Post by Nausea »
If I'm not mistaken (somebody correct me)...
If you can find a donor up to mid-71 (good luck!), then just rob the calipers and hardware and it would spare you from changing out your spindles/kingpins. There are just four 3/4" bolts that hold it all on the spindle. AFAIK, the spindles for disc and drum were all the same.
Just don't forget to get the proportioning valve like I did :cry:
'72 F250 Ranger
Disk brakes, PS/PB, 360 2bbl
Current condition : beloved 'beater'
'70 F250 Camper Special
Currently in the shop, totally stripped
...and yes, you'll also need a disc-drum master cylinder to replace the drum-drum you have now.
i forget the disc drumm is smaller and larger isnt it? or is it both of eqaul size? i cant seem to keep this straight.
FLATBEDFORD
Post by FLATBEDFORD »
Your F250 has a different spindle from the F100. To change to front discs, you need only the bracket, caliper, and hub/rotor from a '73-'79 F250 or SRW F350. The bracket replaces the drum backing plate. Of course you'll still need the master cylinder and proportioning valve. I started a thread on this back in March or February, but I can't find it. It was titled something like "F350 disc brake update" the search doesn't find it. I'll keep trying. I may have pictures to show what I found out with a '67 F350 parts truck and front brakes from a '77 f350.
Steve
My Photo Gallery
FLATBEDFORD
Here's the bracket next to the backing plate.
here's the spindle with the backing plate removed. The bracket bolts right up.
Steve
My Photo Gallery
FLATBEDFORD
I found the thread, manually. I must not have been putting the right keywords in the search engine.
http://www.fordification.com/forum/view ... c&&start=0
My picture links went dead. I think they were the same ones I posted above.
Steve
My Photo Gallery
