17 inch rims
F250Chris
17 inch rims
Post by F250Chris »
Hi!
Actually I have 9.50 x 16.5 LT tires on my ´69 F250 Camper Special with original 8 lug rims. I´m not sure about the rim width.
My question now: Can I use 8x17 American Eagle 058 rims with 255/70-17 or 245/75-17 tires? And what do you think it would look like?
Thanks for your help.
F250Chris
if they will bolt on the rim size probably wont be noticed. as far as the style of rim i dont know. i have different tastes than most guys. the tire size will affect your speedometer reading.
F250Chris
: 17 inch rims
Post by F250Chris »
OK, thanks.
Does anybody know, which 17 inch tires would fit so that the speedometer is not affected?
Greets from Munich
ezernut9mm
Post by ezernut9mm »
try this link. you can compare the proper tire size to any upsize you are thinking about running.
http://www.discounttiredirect.com/direc ... reMath.jsp
Nausea
re: 17 inch rims
Post by Nausea »
255/60r17 or 255/65r17 should get you pretty close. I'm basing 'original' off of the 20+ yr old set on 16.5 rims. They measure out to just a hair over 29" diameter.
Being slightly off won't be of major significance - even with a 1/2" change, the tires would be +/-1.5" off of a 91" travel... like a 2% variance? That said, I bought to get as close to 29.1" as possible.
Also, http://www.tirerack.com is handy for getting specs. After you pick a tire, hit Specs and it will show you the diameters for all the available sizes for that make.
'72 F250 Ranger
Disk brakes, PS/PB, 360 2bbl
Current condition : beloved 'beater'
'70 F250 Camper Special
Currently in the shop, totally stripped
F250Chris
: 17 inch rims
Post by F250Chris »
Perfect, thank you. That helps me a lot.
