brake booster leak?
brake booster leak?
my truck is a '72 f250 with power brakes. when the truck is running and you press the pedal, there is a loud whooshing noise coming from under the dash. the brakes work fine but the noise is really annoying. if you press the pedal as far as itll go, the noise quits but its hard to keep the pedal pressed that hard at a traffic light. any ideas?
'72 F-250 Custom Camper Special 351C, auto (daily driver)
'77 F-100 Custom roller cam 5.0, toploader (gone)
'79 Fairmont Futura, .030 over 302, T5 (new project)
'67 John Deere 60 all original
re: brake booster leak?
Internal booster leak...probably a ruptured diaphram. It's not repairable. Looks like you'll be looking for a replacement soon.
- heep70
Isn't that noise normal because it is sucking air into the back of the booster when pushing the pedal?
Or is it making that noise all the time? Then it would be a busted booster.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
No, the booster can't be sucking air at any time...that would constitute a vacuum leak. The only 'open' area of a booster is the vacuum hose connection on the front. That sucking noise is definitely not normal.
well i figured that was it but i was hoping it wasnt. should i replace it now or is it safe to wait until it dies completely. im a little low on funds right now. ive been driving the truck since March and its made the noise since then. the brakes still feel fine.
I drove my '85 F150 for a year like that. You would still have brakes if it failed, but broken power brakes are harder to push than maunaul brakes.
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
I had the same issue when I bought my truck. It still stopped, but the noise was obnoxious. It cost me about $100 for a rebuilt.
