Lincoln fwd sub frame.
Has any body heard if you can install a lincoln fwd sub frame on the F-100? Apparently the mounting points are the same width as center of our frame rails.
69 F100 SWB
- tazzman68
re: Lincoln fwd sub frame.
Really? I haven't heard this at all, what models/years of Lincoln we talking about? And if you try this, try to take tons of pics!
- averagef250
I saw the front end of a 78 lincoln bolted in to a 77swb 2wd. Looked about as straight up as you could get. The lower control arms are long enough that you can use the factory xmember to mount them on. The width is right for the truck. Only gave about 4 to 5 inches of drop though. I have pics someplace I will try to find them. If not I kinda know the guy so maybe I can get some.
I looked at a local junk yard and saw a few 90's fwd continentals. I was thinking just the suspension but maybe you could switch to fwd if you wanted.
69 F100 SWB
- wt4speed#2
check out 03 and up crown vic's and grand marquis. They have a bolt in aluminum front suspension sub frame including the upper spring cup. the spring cup is no longer built into the frame. From what I could tell it was completely bolted on. I didn't take any measurements yet, but if you beat me to it let me know your findings. Also check out the lincoln Mark VIII IRS set up. could be a possibility.
69 F100 SWB
