Kingpin bushings
import600
Kingpin bushings
Post by import600 »
What is actually done when these bushings are reamed? are they just pressed or is it something more?
kyle
1971 F100 2wd swb 429 C6
390Nut
re: Kingpin bushings
Post by 390Nut »
They are pressed in, and then reamed out (think drilling the inside diameter) to match the size of the king pins, plus a few thousands of an inch, to provide a snug fit.
Paul
`69 F100 390 4spd driver
67heavystepside
Post by 67heavystepside »
:yt: would be correct
did mine on my 67, not fun
import600
Post by import600 »
can machine shops can do this easily?
kyle
Yes, this is a relatively simple procedure that virtually any machine shop can easily handle.
mcarlson11
Post by mcarlson11 »
dont try to do it yourself unless you have a bushing install tool. you WILL ruin your expensive bushings. Its so much easier to just let a machine shop do it.
When the going gets tough, your doing something right.
I agree. I just brought my spindle/I-beam assemblies into the machine shop, where they pressed out the old kingpins and bushings, pressed in some new bronze bushings and reamed 'em out, and reassembled everything. Total cost was about $100, including the cost of the new kingpins. Totally worth it, IMO.
Wes
Post by Wes »
A good front end shop thats knows what it's doing should be able to do it as well.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them :)
Darrman
Post by Darrman »
I gotta ask, how do you know to replace kingpins?
Is it like ball joints, as in wheel looseness?
I tried it on mine the other day, testing it like ball joints and both were solid as a rock.
ezernut9mm
Post by ezernut9mm »
Darrman wrote:I gotta ask, how do you know to replace kingpins?
yes, it's the same. i lifted mine off the ground and grabbed the top and bottom of the tire and rocked back and forth. if there is any play it's the kingpins.
wt4speed#2
Post by wt4speed#2 »
Don't confuse king pin play with wheel bearing play. If it moves and you are unsure if it's king pin or wheel bearing play . have someone else move the wheel in the same manner pushing and pulling on the top and bottom , and lay under the front of the truck and watch the axle eye end , if you can visibaly see any motion of the spindle eyes(top or bottom) on the axle eye your king pins are too loose.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
Darrman
Post by Darrman »
Yeah, when I redid the brakes, I repacked the bearing which were in good shape. There is zero play in the wheels, which for me is good. I just have to get the grease fittings on the kingpins to accept grease, they have been capped with mud for a few years.
I wish I could say the same for the rest of the front suspension, lol.
MadMaxetc
Post by MadMaxetc »
You can screw off the cops on top and bottom of the king pins and spray/soak them in WD40 to remove dried out grease. Just be sure to pump them full of new grease.
Dan
FORD Girl
Photobucket Pictures
