wandering?
JB4020
wandering?
Post by JB4020 »
I have a 71 f100 2wd and i recently put new springs, shocks, radius arm bushings, and axel pivot bushings on. The steering now seems to wander a bit. Will tightening the sector nut on the steering box improve this? The wheels seem to be sitting straight like it aligned ok. It just seemed to steer better before? Thanks for the help
wt4speed#2
Post by wt4speed#2 »
Jack it up and get the weight off the king pins . Make sure all your grease fittings take grease . After greasing turn it wheel lock to wheel lock and shoot just a tad more .Sometimes a dry king pin will cause wandering (road walk).
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
JB4020
re: wandering?
Post by JB4020 »
i will definately do that. Thanks
theskytoucher
re: wandering?
Post by theskytoucher »
IF greasing the pins doesnt help i would try ajusting the steering box!! BUt remember to do it very little at a time and for the first couple times you drive it carry the tools to ajust it with you incase you need to make minor ajustments!!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
wt4speed#2
Thanks Troy ,I got off on the king pin thought and came back to edit no need to now.
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
JB4020
re: wandering?
Post by JB4020 »
I adjusted the steering box a very small amount i try some more. I hope its not out of alignment
RTG_RACING
re: wandering?
Post by RTG_RACING »
You can check the tow witch may cause your problem. Find a center line on the front of your front tires and the back of your front tires. Then measure with a tape between the two. adjust so the front of the front tires are 1/8 inch closer togeather than the back of the front tires.
Jake11
re: wandering?
Post by Jake11 »
Replace the kingpin bushings and the 3 tie rods.If you tighten the box
just a little too much it will get worse.
The KP's are usually most of the problem. They bind up and the steering
won't self center any more.
averagef250
Post by averagef250 »
The twin I beam stuff is indestructible, but one thing I've noticed is once they're dead you should replace everything for a quality end result, this includes kingpins and the "good" bronze bushings. I drove my '70 F-100 300 miles home when I first got it for free. It actually drove pretty good, but when I started swapping an EFI motor in it and decided to swap in power steering too I took a close look at the suspension and realized not only was it shot, but it was a real miracle I drove the truck that far and lived. $400 in parts later it drives better, and I know my tie rods won't be falling off anytime soon.
JB4020
re: wandering?
Post by JB4020 »
Thanks for all the help so fast! The guy i bought it from before i started the resto said he had new king pins put in. Also the steering seemed better before i put the new front end parts on. I have to look into it somemore thanks
ezernut9mm
re: wandering?
Post by ezernut9mm »
if your runnning wide tires they will tend to "grab" the road. my 93 lighting and my buddies 2000 lighting-both with wide stock tires-did the same thing. my 68 with 275-60r-17's will "find the rut" too. when you run wide tieres you need a damper, if you're running stock sized tires i would check out alll the front end components.
AlleyCat
re: wandering?
Post by AlleyCat »
Here's something I've found a couple of times that you might want to look at. Crawl under your truck with the engine off and look straight up at the nut that holds the pitman arm to the steering box.Have someone rock the steering wheel a few inches in each direction.The nut should turn in a circular motion. If it seems rock side to side also then chances are the bushings in the steering box are worn out.Hope this helps.
Clay
JB4020
re: wandering?
Post by JB4020 »
I will definately check all this out. Thanks for the fast and good help
