I am wanting to go to 16" rims on the '72, it has front discs.
I found these and the price is great:
http://store.summitracing.com/partdetai ... toview=sku
Will they fit over my disc's alright?
Will these fit my disc brakes?
- Galaxie64
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
- kaptnkaos
re: Will these fit my disc brakes?
nice looking wheels...
1/2 ton or 3/4 ton? you should be able to call any tire shop and they can give you the bolt pattern measurements for your truck.
good luck
KaptnKAOS
good luck
KaptnKAOS
- wt4speed#2
Check here for measuring wheel lug patterns
http://www.wheelvintiques.com/pdfs/wheel_fitment.pdf
Hope it helps
Hope it helps
- Galaxie64
It is for the F250 I know I need 8 lug 6.5" but I want to make sure a 16" rim will fit over the disc brakes.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
- wt4speed#2
I bought a parts truck that had 3 16.5's and one 16. They were all Ford factory wheels. I hope this helps
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
- Wes
I just this afternoon tried to fit a 16" steel wheel over the HD disc brakes I have for my bump ( 77 d44 hd axle) the wheel rubs on the caliper. I have 16.5 steel and alloy both fit no problem. I am considering 17" or maybe 18" wheels for the bump.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- Galaxie64
Thats what I am afraid of, unfortunately the same wheel in 17's is almost twice as much. But I run 17's on my '97 and '51 so I'd have plenty of take offs available for it. My 2 rear tires are really weather checked and forming a nice crack where the sidewall meets the tread, kind of makes me think twice about going very fast down the road. I may just stick with the 16.5's and buy new tires for them.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
