my first c6 problem
my first c6 problem
installed c6 in my 70 f100 rebuilt with new converter dont have auto shifter yet. filled with 25 pints of fluid seems no matter where shift linkage is set it still wants to to move truck forward. is park all the way towards back of truck or forward? second why does it want to keep moveing forward? does the kick down lever need to be held up in place or if it aint hooked up does it just float? be easy im new . thanks
re: my first c6 problem
sounds like an internal problem. park is forward. 1st is back. If you move the selector all the way forward and can move the truck by pushing it then the linkage is not right inside the trans. If you put it into park and can't push it but start it and it tries to go forward in park then somthing is wrong inside. The ford manual says to set the linkage up you must shift the trans into first and then set the selector on the colum to 1st and tighten up everything. centering any play in the linkage.
iwill try that thanks still wiating for reply from person i got trans from
- wt4speed#2
i guess something is bad inside found park and truck cant be pushed but 1 click down should be reverse and truck still moves forward
Re: re: my first c6 problem
You can find out by taking the pan off and looking up next to the drum. The selector comes through the case and locks into the shift rod. If it wasn't installed correctly it will be stuck in one gear. If you can drive it see if it shifts. If it does then above maybe your issue. If it doesn't shift then its stuck in 1st or the valve body has an issue. Maybe just needs a fluid change. Does it rev freely in park or does it feel like it has a load on it.70FIRSTFORD wrote:i guess something is bad inside found park and truck cant be pushed but 1 click down should be reverse and truck still moves forward
Yep, sounds like a bad tranny to me. I had something very similar happen to me years ago. I had a '68 Ford XL fastback, and did a very hard Reverse/Drive drop...and the tranny immediately started screaming (very high-pitched whine). I stopped and put it into Park, but it still tried to go forward. Turns out that it was stuck in a forward gear, and the car tried to go forward in every gear selection (including Reverse and Neutral).
... and since I'd pulled up to the curb, in order to limp the car home I had to drive forward up over the sidewalk and back out into the street. Ended up just replacing the transmission.
thanks rtg and keith
rtg it has all brand new fluid i will pull pan tomorrow and see what i can see i was hopeing it was a simple fix with out pulling trans again but hey each time its getting quicker. i might push it backwards out of shop click it to where drive is supposed to be and see if it shifts
06 c/c dually powerstroke
04 C5 vette
00 WS6
70 F100 /400m C6
04 C5 vette
00 WS6
70 F100 /400m C6
I have a 77 f250 that was shortened down to a short bed with 60s and 39.5 boggers. It had a bad habit of welding the low reverse clutch pack together. Once it happened it would go forward in every gear and never would shift out of 1st. swapped it out this winter for an np435 and divorced 205. This way I only have one clutch to replace.
kind of depressed right now need to find most economicial way out of this mess . I kind of thought i had it .Where is the best place on the internet to get a C6 I dont have alot of cash right now
04 C5 vette
00 WS6
70 F100 /400m C6
04 C5 vette
00 WS6
70 F100 /400m C6
- wt4speed#2
