Need help finding spindles
Dunnburger
Post by Dunnburger »
I currently have a 68 f100, I have 74 f100 calipers, rotors, master cyl, booster. If I'm not mistaken my current spindles won't work with the disc brakes. So I need to find some 74 disc brake spindles but can't. Please help, and or correct me if I'm wrong, Thanks
mickster
re: Need help finding spindles
Post by mickster »
I've toyed with this too, the stock (drum) spindles won't help for a few reason's. But there is more than one post about putting disc's on these truck's. There are allot of year overlap on these parts. Meaning you are not limited to '74 to finish out the swap. I would start with the donor truck.
I'm guessing it's no longer available. I know this may not be popular but look for another donor and get EVERYTHING this time. The bonus is now you have lots of parts to barter with or spare's. Read the information about the swap first it's here. If time permits spray down the parts with penetrating oil at least once the day before. :2cents:
'68 F100
'69 F100
'80 320i
'02 superduty
'06 freestyle
MadMaxetc
Post by MadMaxetc »
Here is all the info and more!!
http://www.fordification.com/discbrakes01.htm
I have the I-Beams, Radous Arms and Spindles from a 79 here in wichita. I might be able to get them to Aurora or Omaha in mid may.
$50 should cover the gas.
PM me if you want them or want to know more.
Dan
FORD Girl
Photobucket Pictures
