Ok, wuick question. My headlights like to flicker on and off. And i have searched and understand that it is a common problem. And i have read what everyone says is the fix.
BUT... Something about mine that i found out is that when they start doing it, i will dim the dash lights till they are off and it will stop. I tried stomping on the high/low dimmer switch and it did nothing.
Does this mean that my headlight switch is overheating? Too much juice flowing through it? I thought it was strange that this would stop it. You guys think i should replace the switch?
I plan to upgrade the headlight harness myself. But if the switch is causing it, then wouldnt it keep doing it with the new harness/relay setup.
Thanks in advance,,,
Lights flicker... I searched...
re: Lights flicker... I searched...
Does the dimmer switch work? The connections get corroded on
the Light and dimmer switches. Also, theres a breaker inside the light
switch. It can make the headlights go off and on.
Ck. and clean all the connections at the switch/dimmer switch/any
plugs. And grounds. You have a lousy connection somewhere. Follow
the circuit and you will find it.
- heep70
Switch
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 390Nut
If it changes behavior when you dim the dash lights, it's internal at the switch
Paul
![Image](http://img.photobucket.com/albums/v169/FrayedSanity/ford1.gif)
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- adrianspeeder
Re: Lights flicker... I searched...
The load pulled through the switch goes from about 8amps from the headlights to only about 30miliamps drawn from the relay's coils. Still clean and check the switch connector, but you should be good.CA180 wrote:
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
