is a van I beam the same as a pickup?
What about putting the right(van spindle) on the left(truck I beam), and visey-versey? It would make it a rear steer.
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
08 VW R32
re: is a van I beam the same as a pickup?
Would that be inside out,no upside down. Wait let me ask the teen he knows everything just ask
I know I'm being mean so I'll digress
'68 F100
'69 F100
'80 320i
'02 superduty
'06 freestyle
'69 F100
'80 320i
'02 superduty
'06 freestyle
- theskytoucher
I dont think it would be upside down if you changed the ibeam it was mounted to!!! Or you could just put regular truck spindles on it and call it goo right!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
I was making fun of myself. If you put the regular(I think you mean drum spindles) back on you dont have any way of attaching calipers. Unless you make or purchase a bracket for them. Which was the original obsticle I had. But the tie rods are in the correct locations. I think this info is correct, feel free to double check.
I've slept sense I fooled with this.
'68 F100
'69 F100
'80 320i
'02 superduty
'06 freestyle
'69 F100
'80 320i
'02 superduty
'06 freestyle
- Clarko
The early vans 69-74? are rear steer. I have a 69 Econoline in the shop today. They measure about 37 3/8" from center of pivot bolt to center of coil spring mount bolt.
That would mess up your steering angles.nevrenufhp wrote:What about putting the right(van spindle) on the left(truck I beam), and visey-versey? It would make it a rear steer.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
- Clarko
